Lancement : Menu [Analyse] > [Test/Caractérisation de CCD] > [Rendement quantique]
But : Mesurer le rendement quantique de son CCD.
This is a really difficult measurement, because
the result has to be provided in absolute figures, and you MUST
have to input calibration data.
Basic knowledge regarding QE measurement must be known !!
The usual scheme is to use an absolute quantum efficiency
calibrated photodiode installed at the same position as the CCD
will be, and to use flat field images made in the front of an
integrating sphere, fed by one or two monochromators. This setting
allows you to get different flat field images at different
wavelengths and short bandwidth.
The incoming light wavelength is typically ranging from 300 to 1100
nm, with a short bandwidth, such as 5nm. The photodiode current is
measured, and the photodiode manufacturer calibration curve enables
you to compute the amount of photons per square centimeter and per
second. This is an example of a photodiode calibration file (as a
text file) :
# No TABS # ratio bdw 4 # col 1 Wavelength # col 2 Flux on the CCD surface, expressed in photons/sec/cm2 # col 3 Current that is measured at integrating sphere level or closeby to the CCD 320 1.1e+8 0.209e-9 340 2.55e+8 0.544e-9 360 5.18e+8 1.115e-9 380 9.27e+8 2.124e-9 400 1.44e+9 3.646e-9 450 2.9e+9 7.94e-9 500 3.54e+9 10.207e-9 550 3.9e+9 11.5e-9 600 3.97e+9 11.74e-9 650 3.6e+9 10.85e-9 700 3.09e+9 8.96e-9 750 2.35e+9 6.67e-9 800 1.54e+9 4.224e-9 850 1.66e+9 4.52e-9 900 1.42e+9 3.871e-9 950 3.4e+9 8.6e-9 1000 3.16e+9 7.65e-9 1100 2.42e+9 1.224e-9 Afterward, the optical transmission of the dewar window according to the wavelength as to be provided (as a text file).# Window transmission # col 1 Wavelength # col 2 Relative transmission 320 0.94 340 0.97 360 0.98 380 0.98 400 0.99 450 0.99 500 0.99 550 0.996 600 0.9856 650 0.9615 700 0.926 750 0.889 800 0.8517 850 0.8153 900 0.7873 950 0.7627 1000 0.7466 1100 0.723
IMPORTANT : For all the wavelengths used, calibration photodiode text file and window calibration transmission text file MUST match each other. It means that the same wavelengths must be entered in the two calibration files (Otherwise an error will occur). FITS files must include the following HEADER Keywords :
WAVLG = 550 // Central wavelength : Expressed in mn BANDW = 5 // Bandwith : Expressed in mn FLUX = 1.2E-5 // Photodiode current expressed in Amps or 1_FLUX = 1.2E-5 // Photodiode current expressed in Amps
Regarding the CPA image file : if images have been
acquired with PRISM, the previous figures are entered automatically
into the CPA file header.
A reference offset/Bias image (resulting from a median stack of 10
offset/bias images) is mandatory, also the integration time must be
limited in a way that the CCD dark current remains negligible.
Once having entered all the calibration files in the software
dialog box, the analysis window X1,X2,Y1,Y2 must be chosen in the
way that it must not have any serious defects (black hole, bright
pixels).
Conversion factor must have been measured
previously (see method 1 or 2).
Distance during calibration/measurements allows the reference
photodiode not to be at the same distance as the CCD, and to apply
a 1/d^2 correction. This correct for few centimeters effects.
Results :
This is the console output results, for each FITS files, it yields
to :
Wavelength in nm ; Flux in Amps ; Exposure in sec ; Count
values in e-
Filename
Wavelength  Flux
Exposure  Mean    Stddev.Rms  Median
Mean-Median
QE0002.fits
320         1.749E-10
180       21400
484.08      21400
-0.051972
QE0034.fits
340         4.754E-10
180       60662
1281.8      60678
-15.768
QE0004.fits
360         1.0234E-9
79.523    60965
1260.3      60976
-11.264
QE0032.fits
380         2.0072E-9
36.67     60579
832.35      60568
10.537
Qe0006.fits
400         3.5871E-9
20.472    60341
578.48      60342
-1.3613
QE0030.fits
450         8.4612E-9
9.223     60576
473.26      60582
-6.0853
QE0008.fits
500         1.1307E-8
7.248     60050
462.21      60052
-2.3795
QE0028.fits
550         1.3328E-8
6.904     64220
478.24      64226
-5.6408
QE0010.fits
600         1.4012E-8
6.438     59948
446.82      59952
-4.0484
QE0026.fits
650         1.3279E-8
7.296     59910
442.79      59914
-4.2144
QE0012.fits
700         1.1196E-8
9.48      59680
450.23      59686
-5.5382
QE0024.fits
750         8.4697E-9
14.39     59830
481.27      59838
-8.0172
QE0014.fits
800         5.4537E-9
27.831    59990
533.66      60004
-13.601
QE0022.fits
850         5.9775E-9
33.177    59951
508.76      59960
-9.061
QE0016.fits
900         5.1913E-9
58.056    59327
941.36      59162
165.3
Qe0020.fits
950         1.2662E-8
49.111    61606
2471.5      62156
-549.94
QE0018.fits
1000        1.0568E-8
171.99    62739
3667.6      64178
-1438.6
QE0036.fits
1100        1.7114E-9
180       1006
82.472      994
12.022
Image #1 Bandwith :5
PhotoDiode calibration Bandwith :4
Filename
Wav.  PRNU%
QE%       FDio/FDio.cal
Ph/pix/sec e-/pix/sec  %Wind
QE0002.fits      320
2.262      61.065
0.83684
207.12     118.89
94
QE0034.fits      340
2.1125     69.312
0.87389
501.4
337.1       97
QE0004.fits      360
2.0669     73.139
0.91787
1069.8     766.77
98
QE0032.fits      380
1.3742     85.51
0.94499
1971
1651.7      98
Qe0006.fits      400
0.95867    93.401
0.98385
3187.7     2947.5
99
QE0030.fits      450
0.7812     95.421
1.0656
6953.3     6568.6
99
QE0008.fits      500
0.76969    94.847
1.1078
8823.7     8285.3
99
QE0028.fits      550
0.74462    91.842
1.1589
10170
9302.7      99.6
QE0010.fits      600
0.7453     88.622
1.1935
10661
9312.2      98.56
QE0026.fits      650
0.73904    86.151
1.2239
9913.7     8211.9
96.15
QE0012.fits      700
0.75434    78.263
1.2496
8687.5
6296        92.6
QE0024.fits      750
0.8043     69.666
1.2698
6714.2     4158.3
88.9
QE0014.fits      800
0.88938    56.584
1.2911
4473.7
2156        85.17
QE0022.fits      850
0.8485     44.878
1.3225
4939.4     1807.3
81.53
QE0016.fits      900
1.5912     30.209
1.3411
4284.7     1019.1
78.73
QE0020.fits      950
3.9762     14.732
1.4724
11264
1265.6      76.27
QE0018.fits      1000
5.7147     5.0888
1.3814
9821.7     373.16
74.66
QE0036.fits      1100
8.297      0.10033
1.3982
7613.2     5.5222
72.3
Le logiciel renvoie une courbe de rendement quantique (rendement de rêve...) :
et aussi une courbe d'uniformité de réponse photonique :
Voici quelques images à différentes longueurs d'ondes d'une MEME zone (bande passante de 5nm et CCD EEV44 aminci ) : à 320 nm (uniformite dégradée par l'implentation P+ d'un CCD apres son amincissement) :
à 650 nm (très bonne uniformité) :
à 950 nm (belles franges ? non ) :
Methods used :
The method employed here for QE is straightforward and based on the
ratio between the amount of photon falling to the CCD surface for a
given wavelength and the effective amount of photoelectrons read
out at the output of the CCD. This is achieved by all the data
coming from the calibration text files and figures found in the
image file header, such as pixel size, exposure time, flux,
wavelength, etc etc ...
The PRNU computes the histogram of the selected (X1,X2,Y1,Y2) area,
and provide two figures : the intensities at 5% and 95% percentile.
Let's call those figures Int1 and Int2, the PRNU is
(Int2-Int1)/(Int1+Int2)*100%
Focntion script associée :
![]() GetQE
GetQE
Images de test :
![]() Images de test
Images de test
![]() Aucune
Aucune
